purge line
purge line
I know it seems self explanatory, but here goes. The fitting for the purge line has a nut a a brass open oval in it. It seems that I should be able to slip the nut over the far end of the line and put the brass thingy in and tighten down. The problem is I CAN'T THREAD THE BOLT OVER THE TUBING AND THERE IS NO FLANGE AT THE END OF THE TUBING TO HELP TIGHTEN EVEN IF I COULD. There's likely a simple explanation. Any help is needed.
Nick
