Progressive set up w/ M6?
Hey guys, I'd like to run a progressive controller for 1st gear only, and have the nitrous hit full blast in 2nd, 3rd, and 4th. Can this be done and how?
I currently use Nitro Dave's Dual window switch, with WOT activation.
Thank you
Thank you
LS1TECH Sponsor
You can use our 4 dial progressive but it dosent have gears or rpm, it goes by time....
You would set your start %(ex. 20%) and end %(100%) then set the time to just after 1st gear is done(ex. 2 sec) then it will go to 100% at the set time.
The NOS mini-progressive works with time based ramping also.
The FJO Mini-progressive will do time and RPM based ramps but is laptop programmed.
