NX 85mm MAF kit fitment on F-body
I have a Fast Toys 85mm lid, and thought why not get an 85mm MAF kit to compliment such a fantastic product. Apparently, things don't work that way. Am I doing this wrong? When mounted the nitrous solenoid is almost touching the radiator hose, and there is only about an inch between the end of the MAF end, and the throttle body.
My other question, does the MAF end discharge the nitrous at a 90 degree angle? At such an angle, the fuel/nitrous mix would hit the bottom of my throttle body due to the angle of the lid.
Guest
Posts: n/a
I hope that this helps
http://www.nitrousexpress.com/Instructions/1pcmaf.pdf
The discharge come straight out the back. < you could say that it is comes out at a 90* but it's angles toward the back of the intake >
-Chris
-Chris
