how to hook up fuel line for wet kit
Old 07-08-2009, 08:04 PM
awd-rwd racer's Avatar
Default how to hook up fuel line for wet kit
here is a drawing of my current fuel setup. how should i tap the fuel line for the fuel?
Old 07-08-2009, 10:53 PM
SkullV's Avatar
I took the schrader valve out of the test port on the fuel rail and hooked up my fuel line to the test port (Per HSW directions).
Old 07-08-2009, 10:59 PM
01SOMZ28's Avatar
x2 (NX directions)
Old 07-08-2009, 11:29 PM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
are you using stock fuel lines and connectors or is this all braided?
Old 07-09-2009, 07:05 AM
No schrader valve. All braided lines. Speed inc fuel rails. Pretty much no stock stuff is there except for the injectors
Old 07-09-2009, 07:16 AM
nikon1999's Avatar
i got a union with a fuel pressure gauge port (1/8npt) then get a 1/8npt coupling and pop it in. I put mine in between the feed and the start of the rail.
Old 07-09-2009, 09:13 AM
LS1TECH Sponsor
like nikon said, you could put one of these almost anywhere on the rail or before the regulator and get your fuel feed.
-6AN swivel manifold with 1/8npt port.
Quick Reply: how to hook up fuel line for wet kit
