Stock fuel pump, 30 lbs svo's, heads and cam,,, can i still spray?
I was thinking of putting a 100 to 150 shot on my car. If I went with a wet type setup would I have to do more fuel upgrades to be safe? Mods are in sig and the only fuel upgrades I have are the fms 30lb'ers.
Restricted User
I do not have experience with inline, but reading here and everywhere else, the intank is the route to go.
Have your timing in check, no more than 27*or less, and AFR at NA WOT around 13.1:1, changed plugs run either TR6 around .038" or I am now trying 2step colder plug, the TR 5724-8 and with my NXL 180jets will gap at .030 Cover your bases and spray away. Will update the Nitrous list after you do as I am sure you will post some killer numbers.
Ill probably get a timing tuner or some other sort of device that can retard my timing when I'm on the spray, na im at 28 degrees and I have read 3 degrees for every 50 hp is what i need to decrease it by is that right? Also what kind of wet kits would you guys recommend? is the NXL kit the one to get?
