Jet sizing
LS1TECH Sponsor
http://www.dynotunenitrous.com/store...ousjetcalc.asp This will give you estimated HP at the motor.
If you want that power at the rear wheel figure drivetrain loss of 12 - 18% average depending on transmission (auto - std) as well as other drivetrain factors.
You should see similar results assuming the same size jets are used - companies rate at higher HP typically by just supplying you with bigger jets.
Dean
Dean
