103's gapped at .40
Old 07-30-2009, 01:02 PM
w3s1c0a5t's Avatar
Default 103's gapped at .40
Anyone think this would have caused issues at idle while in gear? Also it stumbles when going wot from idle.
Any ideas? only change was plugs
Old 07-30-2009, 06:35 PM
N20SS's Avatar
Possibly. Are you running these plugs for nitrous? If so that gap is too wide.
lifted99GMC's Avatar
I would pull the plugs back out and look for a cracked plug or damaged plug wire.
Old 07-30-2009, 07:17 PM
Nick@HSW's Avatar
Is it only stumbling while spraying or also N/A?
Nick
Old 07-31-2009, 04:39 AM
w3s1c0a5t's Avatar
Asking about a colder plug in the n20 section...
Nick
havent sprayed it yet so only NA data so far.
Also on cold starts, after it turns over and i try to actually get it to move theirs huge hesitation and it falls on its face for about 10 seconds or so then it smooths out and as far as i can tell np's
Old 08-06-2009, 01:52 AM
w3s1c0a5t's Avatar
Update for you guys. The plugs were breaking up and causing the idle issues. Now i didnt get a chance to mess with the tune at all to see if that could remedy it. Pulling them out tomorrow and going to re gap to 30.
Will let you know how that changes things.
Old 08-06-2009, 10:34 AM
Nick@HSW's Avatar
If you pull them and there is a gray glaze over them, chuck em in the trash. Once they get a glaze there is no saving them.
Nick
Old 08-06-2009, 11:23 AM
w3s1c0a5t's Avatar
Nick
Thanks for the input sir.
Old 08-06-2009, 12:41 PM
Nick@HSW's Avatar
Not a problem, that's what we're here for.
Nick
