fuel pressure ?s befor a spray
fuel pressure ?s befor i spray
i just hooked up a wet kit on my 95 lt1, and just to make sure i cheaked the fuel pressure before i hit it. goin down the road it was sittin at like 40 but when it was under WOT i saw like 22 and from what iv read thats not to good for spray. am i right or an i a dumb ***? what should the fuel pressure be. iv got it ready to hit it with a 100 rwhp shot. oh the car has 123xxx miles and as far as i know its a stock fuel pump.
ya dude, just get the full racetronix kit and be done with it. the kit installed in like ten min no joke...super easy man cut the hole ontop and thats the hardest thing to do, i put the harness thru the inside of the car with the relay mounted in the spare well so if i need to do any on road repairs itll take 5 min
Yes you're getting voltage off the alternator...no better source than that.
You also will not see any performance drop with a heavier gauge wire.
If you cannot afford it, I believe there is a write-up floating around showing you how to do it yourself.
Nick
Nick
