Spray Intercoolers on P1SC setup
Old 08-26-2009, 10:54 AM
wakesk8te's Avatar
Default Spray Intercoolers on P1SC setup
I was thinking about maybe spraying the intercoolers on my Dual Intercoooler P1SC setup.. I dont care about making a TON of hp from it.. just mby 30-40hp and make sure I'm not getting any KR.. is it worth the effort to hunt down a cheap solenoid and do it?
Old 08-26-2009, 10:57 AM
BIG_MIKE2005's Avatar
I'd look into meth injection to deter the KR & possible detonation over sprayin the IC.
Old 08-26-2009, 11:02 AM
wakesk8te's Avatar
what kind of HP gains can you get from meth inj?
I was considering a 35 shot dry N2O also
Old 08-26-2009, 11:07 AM
Depends. You really dont wanna use meth for a primary additional power source. It's there to help keep the motor safe, can allow more boost to be run & helps with lower octane fuel or incase you get some bad fuel.
The car needs to be tuned off the meth. If your just lookin to pick up soe power try a pulley swap to make a little more boost. Go live in the FI section for a couple days doin some research. your anwsers are in there.
