Better to lower F/P or change jet to adjust A/F?
Old 09-01-2009, 03:38 PM
TS6
TS6's Avatar
Default Better to lower F/P or change jet to adjust A/F?
If my tune on bottle is a little fat, am I better to lower the FP on my stand alone or keep it up and change the jet to lean it out?
Its a high pressure pump btw, 57 psi IIRC.
Old 09-01-2009, 03:55 PM
Mike@HSW's Avatar
is this a direct port or something else?
Old 09-01-2009, 04:08 PM
TS6
TS6's Avatar
No, plate. 92MM.
Old 09-01-2009, 05:49 PM
slow trap's Avatar
what bottle pressure are you running ? if not high might go up 50 lbs or so to lean it out alittle and gain power to. how far off is it from where you want to be ?
Old 09-01-2009, 06:06 PM
Mike@HSW's Avatar
depends on how much your off. Most likely i would say to just change the fuel jet.
Old 09-01-2009, 07:04 PM
SPEEDYws6's Avatar
I'm still running high pressure too. I had to drop my stand alone down to 45 psi to get it in the ball park.
All the high pressure stuff is jetted for off the rail, but I think it acts a little weird with pressure drop and a bigger jet is needed. Once you change to a stand alone it is capable of keeping up with the demand a whole lot better. So you need to drop the fuel pressure some to get it back where it would have been. IMO
That robietherobot.com program helped me out a lot. Got me started with a much safer tune up than the pig rich tune it was when I first went to a stand alone.
Old 09-01-2009, 07:13 PM
ShiznityZ28's Avatar
Fuel jet would be the best if the sytem works well. at 58psi ou have to lower fp a good bit to make changes. fp adjustments zshould be for minor changes due to weather.
