Need advice on fuel lines from seloniod
Old 09-23-2009, 09:25 PM
TA1364's Avatar
Default Need advice on fuel lines from seloniod
The fuel line coming from the noid to the nozzle seems to be to short. If I screw it into the nozzle it pulls on it and it doesnt sit straight. Also coming out of the exit port on the fuel noid the line turns immediatly making it almost pinch. Did I mount something wrong? Heres some pictures
Old 09-24-2009, 12:26 AM
BakaN20's Avatar
It looks like if you flip it over, it would fix the problem. Where the port that gets the fuel is pointing to the n20 solenoid, looks like it would give you enough length and unwind the fuel line coming in.
Old 09-24-2009, 10:21 AM
TA1364's Avatar
Yea only thing I could think of trying was mounting the selonoid from the other side of the mount.
Old 09-24-2009, 04:27 PM
Chris@NitroDaves
Guest
Posts: n/a
The Fuel hose going to the nozzle does look a little short. I dont know if hsw is the same but NX, ZEX, NOS, and our brand Nitrous Outlet and Brand X kits both the nitrous and fuel lines from the noid to the nozzle are 2ft. The loop in the hose from the rail to the fuel noid inlet looks fine. From the pics that you posted the line doesn't look pinched or kinked at all.
-Chris
Old 09-24-2009, 06:42 PM
john563's Avatar
damn sam!! your actually gonna spray! Thats awesome!! Anyway get it worked out than you could hook up a kit for me lol
Old 09-24-2009, 11:23 PM
TA1364's Avatar
Lol, I almost got everything on. Then starts the wiring.
