Introducing the Nitrous Outlet Progressive controller for only 149.99
Old 11-18-2009, 04:44 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Introducing the Nitrous Outlet Progressive controller for only 149.99
Introducing The Nitrous Outlet Digital Progressive controller for only 149.99.
The Nitrous Outlet's Progressive Contoller is an affordable, compact, and easy to use controller. It will easily fit into small spaces giving you more flexibility in install options. No computer is needed.
This controller has the following features.
Digital Hand Held Controller with LED read out for ease of programming and diagnosis, Conforms Vehicle RPM, Shows wide open throttle activation, shows gear lock out status, and shows activation status.
Can be used as a progressive controller only or use all controller features.
Adjust Start% and Build Time.
RPM activation and RPM deactivation.
TPS activation for falling signal, rising signals, low voltage signals, irregular signals and mechanical wide open throttle.
Multi Gear lock Out Feature allows delaying the stage from activation.
Ground & Hot Output wires allow multiple accessory activations for use with timing retards, indication lights etc.
Hi amp continuous duty circuits.
Reset option for clutch cars.
You can purchase this unit by clicking this link.
http://www.nitrousoutlet.com/catalog...3&product=4004
Old 11-19-2009, 09:57 AM
ls2 bait's Avatar
reset option? i have a manual. will that reset the timer everytime i shift?
Old 11-19-2009, 10:08 AM
Its an option. You can choose for it to restrat exactly where the ramp stoped when you got of the gas or start the ramp all over again.
Myself I restart where it stoped when I let off the gas.
Dave
Old 11-19-2009, 09:31 PM
vicouSS00's Avatar
So what features does this controller NOT have compared to the HSW MicroEdge? Its about a 100$ difference. I'm in the market and ready to buy a controller to complete my 92 mm plate kit and an kinda kicking around which controller would suit me best for my setup..
Kody
Old 11-19-2009, 11:36 PM
I would suggest looking up the features of both units. They are complete different units.
This controller is intended to cover the normal needed basics with out over complicating the install and adding un wanted features rising cost.
This unit does have less features than the unit you are comparing to. I would suggest looking at the features between the two and then educating yourself on what features you are really realisticaly going to use.
Also question what other items you would need to buy to accurately and safely use some of the feautures. Then pick which ever controller fits your needs best.
Dave
Quick Reply: Introducing the Nitrous Outlet Progressive controller for only 149.99
