NX Direct port setup
I have quite a bit of experience with that system. I am not a fan of it. It works ok on some applications and not the best option for many others.
Why dont you tell me about your set up and how much you plan to spray and I will tell you the pros and cons with your plans.
Dave
Dave
Thoes NXL kits are way more trouble than they are worth... steer clear. I wasted a 1/2 of a race season, and 2 sets of pistons trying to get that system to work. I eventually smartened up, and went with a traditional direct port for that motor.
[QUOTE=Nitro Dave's Nitrous Outlet;12526384]I have quite a bit of experience with that system. I am not a fan of it. It works ok on some applications and not the best option for many others.
How does this compare to the NX shark nozzle direct port..Is it just with the NXL direct ports or all NX direct ports such as the shark nozzle one
To the op sorry for the highjack,but thought it might be somewhat helpfull to you as well
NX Direct ports with shark or pirahna nozzles work great, the problem is with the NXL nozzle itself. Like Tony said the NXL pulls a vac on the fuel injector, and traditional jetting goes out the window.
[quote=john563;12528722]
