Anyone using the HSW interface with a wet shot?
I am slowly gathering all the parts for my engine build this winter. I am putting a wet shot on my car, I am going to start at 75 but I am sure I will end up at 150. I am using the HSW plate.
I have the mircoedge controller already and I am wondering about the interface. It seems that it was designed to use with a dry shot but can it be used with a wet shot?
The main reason I am asking is because of the timing retard function. I would like to have a good N/A tune and still be able to run a 150 shot safely. Of course I will be using the correct spark plug.
Any comments or experience would be great!
Jason
Jason
Youre doing exactly what I do. I have their 78mm wet plate kit and I also have the microedge and interface, I use the interface just to pull timing, it pulls three degrees for me when spraying, and im on a 150, all the time. Im running a tad lean right now on the wideband, and as soon as I get around to it, Im going to use the fueling function to add a bit more fuel for me to help richen it up a bit, its a definate plus
