Milling 243 heads w/ nitrous???
Posted this in the engine section also, but I'm looking for all the responses I can get.
I'm having a set of 243 heads worked over this winter. My plan is to have them milled .030" and use stock .051" gaskets. Should put my CR around 11.2:1.
I've been toying with the idea of spraying the car, but I want to know if my deck height will be too thin to spray.
What is the deck height limit when using nitrous? When do I need to go from bolts to studs?
Educate me please...
