hey need i advice
hey need i advice
well i decided to go with nitrous and i brought the dyno tune nitrous brand i will be running a 75 to 100 shot is this good on my parts and what added supplies must i get so my motor could be safe. i have read all the stickys but just askin around thankss. oh and its a wet shot check it out for me and see what i need. http://www.dynotunenitrous.com/store...?idproduct=231
http://www.dynotunenitrous.com/store...?idcategory=23
look into:
window switch - lets you decide what range (window) rpm's you want to spray at.
wot switch - sprays at wide open throttle
fuel pressure safety - quits spraying if theres not enough fuel
air fuel safety shutdown - another option for fuel pressure safety switch. shuts down system if it gets too lean. a lot of people will probly recommend this, but lots of people use both.
someone will have more suggestions, but this should get ya started. just dont go cheap
look into:
yea. and theres lots of really good safety switches/controllers on here. you can either search them or ask questions here if ya have any, there are lots of different ways you can have it set up
So currently all you have is the basic system?
If so I suggest the following. BR7ef spark plugs, Windowswitch with built in TPS activation, Bottle heater, bottle pressure gauge, fuel pressure safety switch and nitrous pressure gauge at the minimum.
If in the budget it would be advisable to get a purge system. Its not as critical as the above.
If you go to a track you will need a NHRA blow off fitting and a blow down tube in order to pass tech.
Nice add ons are switch panels, remote bottle opener, bottle mounts, and a wideband.
If I can be of any assesitance shoot me a pm and I will be happy to answer any questions you may have.
You can also call us toll free and talk one on one with one of our tech advisors for personal advice.
Dave
Dave
