Timing Tuner Wiring Question
Hey guys I just picked up a "HP in a Box" Timing Advance/Retard controller, and have a quick question as to how to wire it up. I have the instruction manual and all, but am wanting to wire it up differently. It has the Grey and White leads that are for N2O control, and what I would like to do is wire it into the lead that goes to my standalone fuel cell to turn the fuel pump on, so that when the system is armed the box is pulling timing. Is it possible to just tap the trigger wire for the standalone, and ground the other?
After you neffy wrap it, wire up the red wire to the black wire. I think that should do it. LOL
Seriously, just wire up the wire from the standalone relay to the 12V wire on your solenoid relay. When the kit is activated your standalone will turn on. Wire in your 12V from the timing tuner to that also, so when you arm your kit, your standalone will turn on, and you will pull timing.
Geez basic nitrous wiring 101 Matt
I tried it that way and it did not work. I wanted it to pull timing b4 I spray.
I wired it up the right way and the until worked like it should. I just don not care for how it pulls timing at the same time you are spraying of the built in window switch.
