few nitrous questions for the 5th gen camaro's
i have a friend who is about to install a kit on his car.. was curious if the fuel pumps support up to a 150 shot without issues? also does anyone have pictures of where they are mounting their solenoids? is there a simple spot on the firewall to run the wiring/nitrous line? anything else that would be helpful please and thank you!
havent found much info on any of this... thank you!
Guest
Posts: n/a
With the way the fuel system is designed and the way it connects to the rails you will run into issues for the most part tring to spray 150hp especially if it's an automatic car. In the autocar that we have done we had to get a new fuel line from the firewall to the rail connection and we added a kenne belle boost-a-pump to the car as well.
Once Dave gets his back from the body shop we will be going to the dyno to see what the results are with and without a boost a pump.
