how to connect two stg in one big show purge ?( post pic )
ok , just now i have my 2nd N2O single nozzel stg and i waiting for my fittings & hoses to start install the 2nd stg , but i still wondering about how & where the best way to connect and brackets the hole system
these are pic of my 1st stg wiring
The big show will come with a manifold that you can put at the connection point on the mainfeed line where you split off to each stage..
On another subject I am looking at your pictures and have some questions. I see tape on the plate fitting connection. YOU should not have that there. It is a compression seal. Honestly you should not use tape anywhere in the system.
Also I see the hardline does not fit well at all? What happen there. Is that why you also have a braided hose on the fuel side?
Dave
Dave
big show purge
Dave
Dave
i'm going to change all the wiring againe thats why i'm asking
regard the tap , this it's my first time install nitrous system and i dont know if i need tap or not
i wont use it next time dont worry
Dave
Dave
And for the braided hose the thread went bad while installing so i had to change it for that. And i wanted everything to be hosses so that there will be flexibility. The nitrous system is installed as showed in the instructions so there is one bottle and 2 solenoids and one more for the the purge system. This stage shoots 200hp on a window switch. i ordered another single nozzle stage and i want to share the hp's between them and i want to share the purge system too. I want the old stage to have 125hp and the other 100hp. That means i will have 5 solenoids, true? 4 and the 5th the big show solenoid. Where is the best place to instlall them? and how to share the purge system between the 2 stages. and the second stage i would like it to be push button. Is that possible? and hints? tips would be appreciated. thanks.
