Nitrous Outlet GM Truck Vehicle Specific Plate Kit
LS1TECH Sponsor
We finally got some time to fabricate the hard-lines and solenoid brackets for the GM 78 and 90mm Truck intakes.
Check them out and let us know what you think.
It will probably be a few weeks to get some solenoid brackets and several sets of the hard-lines made but they are in the works.
78mm
90mm
78mm
90mm
The cool thing about this system is that when you get it the solenoids are already bolted to the solenoid bracket, the fittings are already sealed into the solenoids, the hardline is already made to fit and you simply just bolt it onto the truck.
It is a true vehicle specific system. Not only is the fitment precise and clean this bad boy can flow over 400 hp right out of the box.
Retail for the system with 10lb bottle will be around 699.99.
We will sell the components seperate for the people who already have our system and would like to convert.
Final prices and pictures will be finalized over the next few days.. Then we will do a introductory special for the releasement.
Dave
Dave
