overtightened blowdown fitting w/ burst disk
Old 09-25-2010, 02:35 PM
turbotuner20v's Avatar
Default overtightened blowdown fitting w/ burst disk
So I put on my blow down fitting w/ the burst disk slipped on it and set my tq wrench at 15 ft lbs and went to tighten it... unfortunately it must have clicked right as i started turning and I didn't hear it, so I went about a half turn past 15 ft lbs before I realized it should be tight enough by now.
Does it matter that I over tightened it?
Also, is the standard disk HSW sends w/ their kit 3000 psi? The disk I pulled out of the bottle was clearly labled '3000 psi', but my new HSW disk said like 775psi from what I could read?
Old 09-25-2010, 02:50 PM
Brad@NANO Direct's Avatar
It should say one of the following 3k, 3000, 3.0k. Also, usually if you overtighten them it stretches the disc causing it to burst even when filling. I think you will be fine because it doesnt sound like you went to far with it.
