Who has a window switch for their nitrous set-up? Got a few questions.
Old 01-28-2004, 10:05 PM
14 Second Truck Club
Hemi Killer's Avatar
Default Who has a window switch for their nitrous set-up? Got a few questions.
I think I know how it works. Is this a reliable way to go? I'm trying to go the safest way.
I plan on getting a 2400 stall and would like the nitrous to kick in about 3000rpms and cut-off about 5500. I don't want to spray out of the hole, so I figure that would be the best way to go.
There shouldn't be any problem doing that, right?
Thanks.
Old 01-28-2004, 11:26 PM
blkbeaZ28's Avatar
You shouldn't have any issues. If you have a cam then you might want to set the cut off at 6-6400 rpm's.
Old 01-29-2004, 07:04 AM
I shift about 5900, so I'd figure that I'd cut it off a little bit before. I gotta try a keep the same tranny for awhile .
Old 01-29-2004, 08:36 AM
NOTFAST's Avatar
I'm spraying 3000-5800
I had a buddy go 3000-6000 and he gained about 2mph over just spraying till 5800
Old 01-30-2004, 04:28 PM
Navy David SS's Avatar
If you set the switch at 5500, and shift at 5800, you will really feel the car "bog" from 5500 until it shifts. I have an M6, 3500 and 6000, I shift at 6100 (I do speed shift, and spray thru the gear shifts) . Happy motoring.
David
