Lnc-002 ???
Lnc-002 ???
99 camaro!! First i dont have the 2-step hooked up. What wire on the clutch sensor do i use to hook it it up? Would like to set my nitrous up to come in when clutch is released!!! It's set up now on a wot switch and would like to leave that way. Is there anyway to do this where when 2-step goes off nitrous comes in?
As the guy above said I know progressive have inputs for 5v references that when the transbrake or clutch releases it sends an input to the WOT switch which tells it, it can activate at the set rpm window. If the 2 step has a 5v input you should be able to splice off the WOT switch wire that activates the shot of nitrous to the input on the 2 step so when the 2 step kicks off it allows the WOT switch to activate and spray.
if that sounds weird or if I have something backwards someone with more knowledge can chime in, but I think that's right.
