Couple questions for wiring bottle heater? Size wire and fuse?
What size wire are you guys running back from your battery to your bottle heater? Or what size is recomended? I have 10 gauge and it seems pretty damn thick. Also I bought a 30 amp fuse to put in line. Will that be enuf?
hashtagBMW
Wire size is good, you should run a relay for the heater and not just an inline fuse. The heater relay is triggered by a 12v source which turns it on, thus completing the circuit from the relay to the ground, battery power and pressure switch.
Tony.
Tony.
My heater says it pulls 18 amps. And I measure my wire to be about 13ft. Going by the chart it looks like I'm pushing it with the 10ga wire. If it actually pulls 18 amps I think I will be ok. Going by this other chart I should be fine. Going off yours I'm cutting it real close. Hopefully it will be fine.
[IMG][/IMG]
Going off this chart I even have a little room left....
[IMG][/IMG]
