Nitrous outlet 102 plate question
Most of the nitrous outlet plates have a fuel and nitrous port, can I persay put my fuel line in the port on the plate says nitrous and vis versa. On the 102 single stage
My fuel solenoid is on the passenger side due to my intake set up.
Was wondering if there was a reason they were labeled like that
No you can't swap them. IIRC the nitrous is towards the front of the plate and the fuel is behind it so when the the nitrous comes out of the plate it carries the fuel with it. If you swapped them the fuel wouldn't be carried by the nitrous.
Get you some longer lines and plumb it up
