Nitrous window switchs
well i have all the parts installed and i just need to wire it all up ... BUT i have so many switches i have no clue on how to wire it togather the right way ...
Nitrous Outlet switch panel (arm, heater, purge)
bottle heater w/ pressure switch <---- this is already installed and wired up by itself
WOT switch
Fuel Pressure Safety Switch
MSD Digital window switch
And it has a purge for the WET kit
i went through all of chopstix pics on fquick and didnt see one like mine... any help guys?
WOT switch
I have a MSD digital window switch and have 2 wires left and I dont know where they go. i was hoping that you guys could help me out.
I have the white wire and I know that this one is for the tach signal. I have heard 3 places that people are getting this feed:
#1 off the some wire in the coil?
#2 behind the passenger side kick panel the is a blue or white wire?
#3 and some place on the PCM ?... #10 pin?
Then there is a grey wire ... the wiring diagram that Nitrous Outlet sent me does not have this one marked ... do I just leave this one unconnected?
These are the last two wire I have before I am up and running ... once it is operational I will be heading to the Dyno to get a Full dyno tune and be spraying. Any help you guys can give would be great.
this is true
Also not sure about the grey wire.
Sorry bro.
