Nitrous & Cam
Old 03-01-2012, 08:40 PM
99RedrocketSS's Avatar
Default Nitrous & Cam
Wanting to put a high lift very choppy idle cam in the SS. I also wanna spray this one any suggestions on big cam with will work good with spray?
Old 03-01-2012, 09:43 PM
97camaro383's Avatar
My car has the torquer v3 with a 150 shot and seems to run good but no track times yet. You should look up Tick Performance Polluter Cam or you could always go custom grind
Old 03-01-2012, 09:51 PM
Killer5.3's Avatar
Off the shelf grind Majik Stick V3 works really good with nitrous.
Old 03-01-2012, 10:14 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
As said above those two cams work good for a off the self cams. The main thing that you want to consider is how much nitrous are you wanting to spray on the motor.
If you are looking to spray above a 200hp shot i would recommend getting a custom ground cam spec'd out for you.
Old 03-01-2012, 10:34 PM
dnkynrbk's Avatar
Magic stick 3 cam loves juice. There are guys running 9s with this cam on spray. I used to run this cam its awesome. Or get a custom grind cam to your specs.
Old 03-02-2012, 03:34 AM
MJs1FastSS's Avatar
T-rex.......ftw
Old 03-02-2012, 05:50 PM
It'll get sprayed mostly on the street on Saturday night. I love the way the ms4 sounds, a buddy of mine had one in a 00 ws6. Thanks for the help I'm a little nitrous illiterate.
Quick Reply: Nitrous & Cam
