msd digital window switch install help
Ok I have already had my system hooked up for awhile, but I am now deciding to hook in a window switch for safety purposes. Ok so here is how I am seeing it.
Red-Power
Black-Ground
White-Connection to computer-coil wire
Yellow-supplies ground for my nitrous relay
My 2 main questions are #1 What is the easiest way to splice into the computer-coil wire and not f*** anything up? And #2 I already have a ground wire for my relay for my nitrous kit hooked up. So would I unhook the ground to it and use the msd window switch for ground to it with the yellow wire?
Red-Power
Black-Ground
yes on the secound question and i have no idea on the first. i have a lt1. do you have a aftermarket ignition box? thats where i tapped into my tach wire and i would use a presure switch to. just to make sure you have enought fuel presure if not it shut the relay off. but this is exzactly how i had mine ran. i actullay had two of them hooked up for two stages
Red-Power
Black-Ground
Red-Power
Black-Ground
2. Yes, use the yellow wire in place of the old ground.
The connector allows two wires to lay side by side and when clipped are electrically connected. Not my fav way to do it, but it works.
Yeah, that sounds right on RPM.
Anybody think the above^ sounds like a good idea or should I have it come in earlier? I figure with the tires already traveling a good speed having it come on at higher rpm I willl have alot less chance with wheel spin in 1st. Does that sound right or just dumb?
sounds 100% plausible. i thought you had a 6speed.
I originally had my power wire to the nitrous activation switch( I have a dynotune switch center). The problem I was having was the digital box needs a few seconds to load because like you I had a 6 speed at the time and didn't want to spin I wanted to turn the spray on if I new I would spin on the initial hit. So if I ran someone on the highway from 40 or less I would just turn it on in 3 or 4th gear. Being there us a delay I got very annoyed and now the power to my switch panel is a keyed 12 volt source and the positive or the window switch shares that. This way once the car is started is already booted up and read to go. I don't know if you have this problem or hooked it up this way to begin with but just sharing my experience.
