Nitrous setup.. ?
Nitrous setup.. ?
I am looking to put nitrous on my 2002 Camaro Z28. I have a built 403ci motor, th350 tranny, full suspension, strange engineering 12 bolt rearend. Car weighs in at 3540lbs and the motor was built to handle a 400hp shot. I want to spray the car with a 200shot. I have already sent the converter out to get cut for the spray and should have it back this week. I started a list of stuff I may or maynot need so if anyone can help I would appriciate it. I called one local shop and this is the lineup that was given to me but they are a little high on the price. I wasn't expecting this stuff to cost $2500.00-$3000.00 not including installed price. I want to be on the fence with this setup. Meaning I don't want my car to be a Nitrous car. With my N/A setup now I am running 10.30's@129-130mph.. Any help with what to get or what vender to use would be great.
Thanks..
Here is a list I already have. I'm not a 100% sure on what parts I need or don't need so please chime in. Thanks..
NO-00-10118-90-... Nitrous Outlet: 90mm Fast Intake 98-02 F-Body Plate
System (10Lb Bottle)
NO-00-61001 Nitrous Outlet: Progressive Controller
NO-00-12001 Nitrous Outlet: 98-02 F-Body Fuse Panel Dedicated Fuel
System (plastic not stainless)
NO-00-01153 Nitrous Outlet: 1/8 NPT X 6AN Straight Fitting
NO-00-64001-4 Nitrous Outlet: Nitrous Outlet -4 Bottle Heater
(15LB/10LB Bottle)
NO-00-62000 Nitrous Outlet: 4AN Purge Kit
NO-00-63001 Nitrous Outlet: Luminescent Nitrous Pressure Bottle
Gauges
NO-00-35000 Nitrous Outlet: Male NHRA Valve w/Pressure Relief
Disk
NO-00-35020 Nitrous Outlet: 180* Blow Down Tube (Black Fitting)
NO-00-65000 Nitrous Outlet: 4an Nitrous Filter
Thanks..
(15LB/10LB Bottle)
Gauges
Disk
