Nitrous valves where air pump used to be
I am installing a zex kit on my car and i am going to put the zex valve module and the MSD window switch where the air pump used to be. I have already mounted the zex module and msd switch on the existing bracket that the airpump was bolted to.
My question is can i pigtail into the existing 12v that was for the airpump? Then i would just use the ground terminal located on the fender well. I am going to run a 8 conductor cable from the ashtray switch to the zex module and msd switch. So i figured i would use 1 of the wires as 12v and 1 as ground. Just need to know if it is ok to pigtail onto the exhisting 12v power supply that was for the airpump. I hope i made it clear enough.
Thanks
Thanks
