Fuel feed question?
Fuel feed question?
I just picked up a fast setup and on the rail sit has the fittings to run a feed and return but since I'm still running the pump in the tank I don't need a return so I was goin Toby the fitting to block it off but before I do that could I use that side to feed my nitrous system or should I jus run a y from the feed line.
