NGK plug info! HELP!
The NGK R5724-10 (7993) is a heat range 10, but it is a protruded tip plug, do they make a NGK in a 10 heat range that is a Non-protruded tip plug? if so please whats the part # for a LS style head, or what are you N20 guys running for a 10 non-protrude plug?....Thanx.
I know of some nitrous guys that still use that projected heat range 10 when it's really cold outside.
Turn the timing down a 2*-3* and use this plug again only when it's cold and the DA is really really low as in - numbers.
B10EFS is the non projected tip -10 NGK.
I wouldn't use an Autolite unless you are familiar with the way they read.
