Where to put inline fuses on N2O install
Quick question, as I'm not really an electrical person. I plan to put inline fuses on all power sources(heater/solenoid relay/remote opener). Does it matter where I put them. On the main power running from a relay to the device, I'm going to put them on the output side of the relay, but for the powered lines running from the switch panel I'm not too sure. Take for example the bottle heater...
I plan to put an inline fuse between the power out on the relay to the heater lead. I was also planning to put a fuse on the low-amp lead running from the switch panel to the relay. Should this inline fuse go between the switch panel and the relay OR should it go between the power source and the switch panel OR it doesn't matter.
Thanks,
Mike
Thanks,
Mike
