Timing tuner and MSD 2 Step?
I've already got a Timing Tuner for my nitrous setup. I'm going to use that to pull timing and as a window switch. My question is if I install a MSD 2 step to control RPMs during launches will I have any problems? Will one cause any issues for the other?
Nope. I keep the throttle just below 100% while I'm on the 2 step so the WOT switch doesn't activate....then when I release the clutch, push the throttle the rest of the way. The 2 step is wired to the starter safety switch (black switch that's depressed with the clutch is on the floor).
