LS nitrous questions
I am new to the LS engines but not new to nitrous. I just recently bought a 98 Trans Am with the Nitrous Express 2pc MAF kit. The system has not been wired yet nor has the car been tuned. The car has a comp cams XER281HR cam and fast 90mm intake and nick williams 90mm TB, also a racetronix kit with walbro 255.
What I am trying to find is how far can I push this fuel system. I have been searching and researching and will contiue to do so. I have learned that I will need injectors, and tuning software is on the way.
Any suggestions would be greatly appericated.
If your Nitrous system is a wet system, the additional Fuel for the nitrous system is supplied by the Fuel solenoid. Im using an LNC 2000 Timing computer to pull timing when the Nitrous system is activated. The Racetronix Walbro 255 kit is good for 550 H.P.
Check with Lonnie. He is a sponser here on LS1 Tech. ( Lonnies Performance).
Lonnie really knows alot about fuel systems. Make sure you are running the Hot wire kit with the 255. Its the upgraded Heavy Duty wiring harness kit that should be used with the 255.
Yes the kit is a wet kit and I do have the upgraded wiring harness.
I was just unsure about what the fuel systems limit was. I have done enough research that I have a pretty good start on it.
Since this car is going to be a all out drag car I am not concerned about pump gas or how long the motor will last. Basically I just useing it as a learning platform while seeing how fast I can get it.
Thanks for the info and please keep it coming
