Lingenfelter LNC-2001 Timing retard/ launch control for LSA/ LS9's
Old 08-08-2013, 10:25 AM
Ryan@Lingenfelter's Avatar
Default Lingenfelter LNC-2001 Timing retard/ launch control for LSA/ LS9's
Sometimes referred to as a 2-step or launch controller, the LNC-2001 adjustable RPM limiter and timing retard controller can be used to provide consistent launch RPM off the line in drag racing and other standing start racing applications. In turbocharged applications the LNC-2001 can also be used to retard the timing in order to build more boost at the line.
The LNC-2001 can also be used as an adjustable individual cylinder RPM limiter, providing reliable and fast acting spark based engine RPM limit control. This is especially useful in vehicles that have auxiliary fuel control systems where it is not possible to make sure that both the factory ECM/PCM and the auxiliary systems both turn off fuel at exactly the same time. If the two don’t completely cut fuel at the same time you will run lean when the one system cuts off the injectors, risking severe engine damage.
The Timing Retard capabilities of the LNC-2001 can be used to retard timing by up to 15 degrees. For nitrous oxide applications the timing retard can be activated using the dedicated timing retard activation input to the LNC-2000. In turbocharged and supercharged engines the amount of retard can be controlled by the boost level using the 3 bar MAP sensor input. The LNC-2000 can also be used to retard the timing at the line to build boost in turbocharged vehicle applications with or without the launch control RPM active. The Timing Retard function can be used by itself or while the Launch Control RPM limit function is active.
http://www.lingenfelter.com/mm5/merc...=#.UgO2177D_5o
Attached Thumbnails Lingenfelter LNC-2001 Timing retard/ launch control for LSA/ LS9's-l460216509_900.jpg
Old 08-08-2013, 11:35 AM
HCI2000SS's Avatar
Wait...Is the 2001 a newer version of the 2000 basically?
Old 08-08-2013, 11:40 AM
brandon@nitrousoutlet's Avatar
It is for LSA/LS9 applications. LNC-2000 is for all the other LS motors.
Old 08-08-2013, 12:15 PM
Thank you for clarifying!
Old 08-18-2013, 10:46 PM
Smokin92z4's Avatar
Brandon tell Dave next week add one of those to my order that Vic jr elbow intake thanks
Greg
Sounds like there bad *** units
Old 08-19-2013, 04:57 PM
Originally Posted by smokin92z4
brandon tell dave next week add one of those to my order that vic jr elbow intake thanks
greg
sounds like there bad *** units
10-4
Old 08-22-2013, 04:31 PM
Smokin92z4's Avatar
Default ,
thanks also changed to the super vic its coming to ya lol and dave got the 4150 tb on top
Quick Reply: Lingenfelter LNC-2001 Timing retard/ launch control for LSA/ LS9's
