Fuel Syestem for sale(pics)
Formerly 4mulaJoe
http://torqueaddicts.com/media/Fuel%20Cell/index.html
2 gallon fuel cell
holley blue electric pump and regulator
8an from cell to pump
8an moroso filter
6an from pump to regulator to selenoid
manifold fitting and fuel pressure gauge included
custom mounting bracket
As you can see it is mounted below where the battery used to be. There should be enough line here for you to mount it wherever you could find room though. I have around $600 in this setup total and only used it once to test it out and decided to go a different route. $350 +shipping.
2 gallon fuel cell
8an moroso filter
I have a TNT F1 Kit also. Would this just be for the N20 setup, it wouldn't affect the stock fuel system in the car? How is the pump attached by the tank. I am looking for a different type fuel system for my setup, I already have a walboro 340 in-tank pump that I need to install. Can you email me with details of how the setup works at bheusmann@nvethis.d2g.com Thanks.
-Bryan
-Bryan
Formerly 4mulaJoe
The pump is attached to the cell via 8AN fittings with a 8AN Moroso fuel filter inline between the pump and fuel cell. This kit works independent of your stock fuel system. It would be used just for the nitrous kit. You run the 6AN hose to your fuel selenoid to supply fuel for the nitrous kit.
I've sold the kit 4 times now. All 4 have backed out. 5th time is the charm.
Formerly 4mulaJoe
Still for sale.
Originally Posted by BIGBOS
If its still for sale in a week or so, consider it sold
If my supercharger stuff doesn't workout I'm going back to an N/A - Spray setup
Formerly 4mulaJoe
I called TNT to get the jets I needed. They can fiure out which fuel jet will give you the same volume of fuel with the low pressure.
Originally Posted by H82BBad
I am interested but I am wondering what you did for a fuel jet using the low pressure fuel system?
