NX remote opener wiring...
Old 05-05-2004, 10:58 PM
AgentOrange's Avatar
Default NX remote opener wiring...
Got a used one and it didn't come with relay or anything. The NX site show s how its wired but what type of relay is that, its not listed. Kind of looks like your typical Hella or BOSCH automotive relay. Any wiring suggestions? Current pull of motor??
Old 05-06-2004, 12:53 PM
Nitro Dave's Nitrous Outlet's Avatar
The remote opener does not come with a relay.You do not need a relay for the opener.There is a wiring scamatic on NXs web site.
Dave
Old 05-06-2004, 05:06 PM
Dave
Well thats the problem. It did not come with the switch either so the install instructions do not help. What kind of switch is it (i.e. - SPDT, SPST)
Old 05-06-2004, 07:28 PM
ZL1SS's Avatar
Default Switch
You will need a double throw switch with 2 rows of solder tabs> a total of six tabs in two rows of three. The switch needs to be off when in the middle position and have a temporary (on) when you hit it up and down. The NX opener only has two wires and it alternates the ground thru the un-hot wire. No relay is needed!!
Old 05-06-2004, 09:03 PM
so I need a monetary double throw double pole switch that would look like this:
nice..any better wiring diagram then NXs?
It would be like this right?
.to motor (red) + | | - to motor (black) |
. |_____________ |
. battery - | | + battery | |
. |_____________________|
Ok this won't display the spaces right but any way the middle two legs are GND and a +
One of the sets of outer legs have the GND & + of the opener
One set of legs are connected criss-cross to the others reversing polarity of the motor.
Old 05-07-2004, 08:13 PM
ZL1SS's Avatar
Default wiring
That is correct my friend!! Good luck with it. Once you figure out how it works it is easy to wire up.
