Ls3 top end on 99 fbody, Need a nitrous plate
Old 11-06-2013, 03:52 PM
07_Turbo's Avatar
Default Ls3 top end on 99 fbody, Need a nitrous plate
I have a ls3 top end on a 6.0 lq4 and im running a nick williams throttle body. I have a tnt dual stage that sorta works with my set up and throttle bracket and a nitrous outlet that want fit at all. Im looking for a plate to work with my throttle bracket from the ws6 store that attaches to the throttle body. Ive tried running the other bracket from ws6 store that uses intake bolts but caused a vac leak. Spraying a good size shot and need a plate to do it.
Old 11-06-2013, 04:02 PM
brandon@nitrousoutlet's Avatar
http://www.nitrousoutlet.com/efi-nit...onversion.html This is our side entrance 90mm plate. You might have to trim that bracket some assuming this is the one you're referring to:http://www.ws6project.com/user_stor/...oducts_id=4692
Old 11-06-2013, 11:32 PM
07_Turbo's Avatar
Thats the exact bracket i have. Now is that plate thinner that the traditional 90mm plate that yall sale because im having trouble retaining my maf with the nitrous outlet plate i have now
Old 11-07-2013, 09:37 AM
That plate is .75" thick and should be the same as the one you have now. Shoot me a picture of what you have if you get a chance: Brandon@NitrousOutlet.com
Old 11-07-2013, 01:42 PM
07_Turbo's Avatar
Email sent Brandon thanks for your help!!!
Quick Reply: Ls3 top end on 99 fbody, Need a nitrous plate
