newbie to nitrous have some questions!
so im planning to spray a nitrous outlet wet plate kit. around 175 shot to my 383 ls. my combo has 11.6 to 1 compression. right now im running tr6 plugs. you think i shuld run tr7s? right now my fuel system is a ractronix pump with hotwire kit, 42# and fast rails.
also can someone please explain how the dedicated fuel systems work? and if it would benefit me running this
As for a dedicated fuel system, I'd recommend the Nitrous Outlet Stand Alone. Pretty much you wire it up so when you arm your nitrous, the fuel pump in the stand alone is activated which then supplies fuel to the Fuel Solenoid. Once you actually "spray" then the fuel has already reached operating pressure.
