Nitrous help ?
Old 12-16-2013, 03:23 PM
IzaguirreZ28's Avatar
Default Nitrous help ?
I was on Nitrous Outlet a couple of minutes ago and i saw a Dry, Wet, and Alcohol. Can Anyone Specify what are the differences.
Old 12-16-2013, 03:31 PM
HCI2000SS's Avatar
http://www.enginebasics.com/Advanced...0vs%20Dry.html
Goggle works wonders
Old 12-16-2013, 04:03 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Dry system sprays only nitrous. Wet system sprays nitrous and fuel out of the same plate or nozzle. Alcohol usually refers to water meth injection, or a wet system that sprays alcohol instead of regular gasoline.
-Garrett
Old 12-17-2013, 09:58 AM
brandon@nitrousoutlet's Avatar
Our Dry system will spray nitrous only and require you to bring the fuel in via the injectors. The wet system will spray both nitrous and fuel and the alcohol system is for those who are running their cars on alcohol and has some changes to the fuel solenoid to compensate for the increased flow requirements. Let me know if you have anymore questions and I can help you out!
Quick Reply: Nitrous help ?
