Wiring help - Mallory window switch with TNT dry shot
I'm at the last part of the wiring (again...) and have come across a problem. I think I have the right idea, but not sure. This is what is currently connected
This is what the relay has...
87 <--- TNT solenoid
WOT switch -> 86 85 <--- ????
30 <-- power /w inline fuse
Another way to read it:
87 goes to one of the wires to the solenoid
86 goes to one of the two WOT switch male ends
85 goes to ????
30 goes to power source with inline fuse
The diagram I am using says the middle one is NOT used
MALLORY WINDOW SWITCH - 7 wires, black, red, green, 2x orange, 2x purple
Black, one orange, and one purple are lead to ground
Green taps into the tach wire
Red leads to power
The other orange ????
The other purple ????
Now, what the Mallory thing says is that one orange wire turns it on, while the purple turns it off (at selected RPMs), and the remaining orange and purple go to a ground
ARMING SWITCH has 2 male ends
One wire goes from arming switch to WOT switch
So what I THINK I need to do is...
Connect orange wire from RPM window switch to 85 on relay box
Connect purple wire from RPM window switch to arming switch
This is the last step I have, I am close to having this crap work, I hope I have the right idea here. Any feedback please, thanks
85 goes to ????
Red leads to power
