2 stage setup
2 stage setup
Hey guys I have a qeustion.
I have a 92mm plate that I have had for a couple years now. It seems to be an older plate compared to the newer ones created now. It has 4 inlet ports. 1 on each side and 2 directly behind it straight off toward the back. I'm using the two back ones currently. I am thinking of adding a second stage to my setup. Could I possibly use the other sides for the second stage? I know the plate can support the flow but all the plates I have seen are 2 stages directly off the back. Can it be done? Maybe support 250 total?
https://ls1tech.com/forums/parts-cla...ous-plate.html
Sell your plate to him for $200.00 and get the Nitrous Outlet dual stage for $349.00. You're out only $150.00 bucks. Unless you can get more for your plate. Plus IMO, a cleaner install.
