upgrading fuel system
Old 04-29-2014, 08:17 PM
bert07silverado's Avatar
Default upgrading fuel system
Can I use a boost a pump instead of replacing my factory pump? I am going to spray a 150 shot and want to make sure I have enough fuel.
Old 04-29-2014, 09:15 PM
Hardcoresoldier's Avatar
absolutely! Make sure it turns on when you need it, either by window switch or vacuum switch. Mine is set to turn on at 4" vacuum which I should hit long before I hit WOT. If not, I will adjust it.
Old 04-29-2014, 09:19 PM
ok thanks for the reply. What bap are you using?
Old 04-29-2014, 09:25 PM
KB. It is hard wired so that when it is "on" it runs at 100%. I wired it to run off engine vacuum because I want it to work when I am on the throttle but not on the bottle.
Quick Reply: upgrading fuel system
