Afr or tfs heads
Old 07-20-2014, 11:53 AM
loosews6's Avatar
Default Afr or tfs heads
Looking to upgrade my heads. Any suggestions on a good set? I have a 408 nitrous motor; iron block, spraying 300-400 shot. It is hyd. roller, but thinking of going solid roller when I get the heads. I have a ported super victor intake now,Shifting at 6900. 530 to the tires on motor, with the ported TEA 5.3 heads. best et is 5.65 @ 121mph....leaving on a 300 shot, this is with 1 3/4 header just bought 2" kooks...end goal I am wanting to run 5.40's.
Old 07-21-2014, 07:51 PM
loosews6's Avatar
anyone
Old 07-21-2014, 09:23 PM
Killer5.3's Avatar
Give Brian Tooley a call. TFS 245 and a nitrous cam from him should get you where you want to be.
Old 07-22-2014, 10:23 AM
Rise of the Phoenix's Avatar
Either the AFR or the TFS heads would work well. I think the TFS 245 heads would be a little better than the AFR's, but you really can't go wrong with either.
Old 07-24-2014, 08:47 PM
loosews6's Avatar
thinking about the tfs 245 with nitrous exhaust port...
Old 07-24-2014, 09:15 PM
Those would be a great choice. Hit up Brian Tooley, he'll get you setup right.
Quick Reply: Afr or tfs heads
