tapping plastic fuel tank for inline pump
has anyone ever tapped the plastic tank to run an inline pump to feed the nitrous system by itself so there is no lean spike and to keep from redoing my current fuel system.?? This is on a 200o z28
Ls1tech & Truck Sponsor
Most people just run one of these setups.
http://www.nitrousexpress.com/produc...&keyword=15004
Its its own seperate fuel system specifically for nitrous. The pump in the 15004 handles around 700hp at low pressure, plenty for one of our direct ports.
Now, back to your original question, you may be able to tap it and use some JB weld, that could be hit or miss though, I've never messed with a plastic tank. I'm sure others will chime in.
-Garrett
-Garrett
I've helped a couple of customers with this setup but it was on C6 Corvette's. They used an inline pump, 2 filters and the regulator mounted up under the hood. You will need to drill two holes. One for the feed and one for the return. I'll see if I can't find the parts list that was used.
(1)-1/2NPT X 8AN
(1)-1/2NPT X 6AN
(1)- Aeromotive 12324
(1)- Aeromotive 12321
(1)- Aeromotive 13129
(1)- Bosch 044 Inline Pump
(15ft)- 8AN Teflon lined fuel hose
(15ft)- 6an Teflon Lined Fuel Hose
(2)- Flo-Supply 6 AN Straight Performance Flex Hose End (Black)
(6)- Flo-Supply 8 AN Straight Performance Flex Hose End (Black)
Here is that parts list.
(1)-1/2NPT X 6AN
