bellow fitment for power ring
im using the slp bellow and am installing the tnt power ring kit, and im also using the tsp lid, for you guys running this setup, did u just trim the bellow, the end closest to the maf or both ends, b/c without cutting it it has a long damn way to come so the lid will fit do i need so replys thanks
I used the direct flo bellow which is similar to slps. Trim a tiny bit from each side at a time and install and check fit. Use the large hose clamp and tighten it around the bellow as a marker for cutting and trim with an xacto. Trim more until it fits perfectly. If you take your time it should fit great.
