purge set-up help
purge set-up help
I have the nitrous express nxl kit and wondering if I need to our a purge valve on each fuel rail or at the y fitting going to the rails...... I figure to assure all air is purged need to put one on each fuel rail but I'm not expert so That's y I'm asking thanks in advanced
Ls1tech & Truck Sponsor
I would just use one purge and set it up off that y fitting in the picture. On some applications you can use the purge port on the fuel side as a return setup, but this application specifically, you can't.
Here is a link to the fitting I would use to mount the purge.
http://www.nitrousexpress.com/15502-...ple-ports.html
-Garrett
-Garrett
Thanks Garrett will do I'll get this when I order the new jet pack actually I called last week to order and you weren't in.. been sicker then crap so get heeled up I'll give you a shout 🏁
