n2o "bump"
n2o "bump"
how do you guys that run a nitrous "bump" wire that up? is it just a button or switch to activate the n2o side separate from the other wiring needed? I plan on running a stinger plate and was curious if purging through the engine was a good idea or even doable. 2-300 shot set up
Ls1tech & Truck Sponsor
You would wire the " Bump " separate so you just activate the system by itself devoid of any safety electronics. If doing so I'd wire it up on a button. People have and continue to " Bump it " through the motor but in my opinion I wouldn't recommend it. But then again that's personal preference.
-Chris
-Chris
