1/8" NPT off Y-Block for fuel?
OK, let's be honest... I don't know what the hell I'm doing with nitrous. I ran a "plug & play" 75 shot back in the day but that's the extent of my experience with it.
Engine is a MID sleeved, built LS7. Making a ton of changes, the "plan" is to crack 600 whp all motor. I'd like to take baby steps with nitrous and eventually work my way up to a 200 shot.
So... fuel system currently consists of an Aeromotive 340 in-tank pump, -8 feed to a Y-block, dual -6 to each rail. -6 out of each rail to an Aeromotive regulator and -6 return back to the tank. 58 psi.
My Y-block has an 1/8" NPT port for a gauge hookup. Can I pull (enough) fuel off of this port to support my goals? I was thinking a direct port setup but, admittedly, I don't know what the hell I'm doing. My gauge block looks like this:
I'm at a point now, because I'm re-doing my hose routing, where if I was going to use this Y-block option, "now" would be the time to at least plumb the fuel side for easier access later.
BTW, the nitrous will be controlled by a Holley Dominator ECU.
Thoughts?
Thanks,
Ryan
Thoughts?
Thanks,
Ryan
not on a 200 shot. why not just another y before the y that goes to the rails. so your thinking 600 on motor then 200 on nitrous?? I would use a stand alone then for sure.
Ls1tech & Truck Sponsor
I would say probably not on a 200 shot. Alot of times they only drill out those 1/8 ports on the regulators/y blocks just enough to run a pressure gauge. You could plumb one of these off the rail, or run a seperate regulator off your main feedline if you want the ability to tune the nitrous system independently. Here is the link to that fitting..
http://www.nitrousexpress.com/15502-...ple-ports.html
Thanks,
Garrett
Thanks,
Garrett
Appreciate the input, guys. How about routing a single -6 feed to the rails off the Y-block and using the other -6 to feed the fuel solenoid? Then just tieing rail to rail and back to the regulator?
Ryan
Ryan
I had it in my mind that the wet system would be "safer" but, admittedly, I haven't really researched the dry system setups that much. What are your thoughts on this with the Holley?
If you have a good tuner, dry would definitely be another option with that ECU. 6an will only support about ~500hp (Through a single feed line). I would definitely at least be feeding the motor with a single 8an if you decide to go that route. Simplest thing would be to put that adapter inline on the end of the rail that I linked and run it. It will definitely support 200hp out of the 1/8 port in that fitting.
Thanks,
Garrett
Thanks,
Garrett
